Manually configure the port speed.
The following table defines parameters for the speed command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Specifies the port or ports that you want to configure. |
10 |
Configures the port speed to 10 Mbps. |
100 |
Configures the port speed to 100 Mbps. |
1000 |
Configures the port speed to 1 Gbps. |
10000 |
Configures the port speed to 10 Gbps. |
2500 |
Configures the port speed to 2.5 Gbps. |
25000 |
Configures the port speed to 25 Gbps. |
5000 |
Configures the port speed to 5 Gbps. |
